From the lobby to the storage room, Orbi Pro Tri-Band Wi-Fi System (SRK60) covers up to 5,000 square feet with high-performance AC3000 (3Gbps) Wi-Fi. First with innovative Tri-band Wi-Fi, Orbi Pro helps deliver the fastest available Internet speeds as more devices connect. This Orbi Pro Wi-Fi system comes with an Orbi Pro Wi-Fi router and satellite and replaces your business router. It also easily works with existing business service provider equipment so you will enjoy better Wi-Fi everywhere in your business.
Product Description | NETGEAR Orbi Pro SRK60 - Wi-Fi system - 802.11a/b/g/n/ac - desktop, wall-mountable, ceiling-mountable | Device Type | Wi-Fi system | Enclosure Type | Desktop, wall-mountable, ceiling-mountable | Wi-Fi System Components | Router, extender | Wi-Fi System Coverage | Up to 5,000 sq.ft | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Features | Captive Portal, MU-MIMO technology, beamforming technology, Tri-Band, guest access | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 17.3 cm x 8.38 cm x 24.6 cm | Weight | 934 g |
General | |
Device Type | Wi-Fi system - 7-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2-PSK |
Wi-Fi AC Rating | AC3000 |
Line Properties | |
Line Coding Format | 256 QAM |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , LAN: 4 x 1000Base-T - RJ-45 - on extender |
Aerial | |
Aerial | Internal |
Antenna Qty | 6 |
Power | |
Power Device | External power adapter |
Installed Qty | 2 |
Miscellaneous | |
Included Accessories | 2 x wall mounting kits, 2 x ceiling mounting kits |
Cables Included | 1 x network cable - 2 m |
Dimensions & Weight | |
Width | 17.3 cm |
Depth | 8.38 cm |
Height | 24.6 cm |
Weight | 934 g |
