NETGEAR Orbi Router and Satellite Extender Home Wifi Kit
£379.11
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Better Wi-Fi everywhere
  • Max Internet speeds
  • Just plug in
  • Type: Wi-Fi system
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
  • Speed: 3Gbps
  • Stock Status: In Stock
Product codes
Meet Orbi – Fast, Secure, Whole Home WiFi
Orbi is the World’s First Tri-band WiFi System. From your front yard to your home office to your pool, Orbi gives you reliable, secure, and crazy fast WiFi to every inch of your home.
WiFi Everywhere
No more dead zones upstairs, no dropped connections through walls, just WiFi everywhere. The Orbi Home WiFi System reaches up to 4,000 square feet through WiFi barriers like walls, stairs and doors. Need more coverage? Just add an Orbi Satellite to instantly expand your WiFi reach.
Don’t Wait on Buffering
Buffering shouldn’t be a part of family movie night. Orbi helps prevent buffering and lag by creating a high speed Internet superhighway for all of your devices. The Orbi Tri-band WiFi System works with your current ISP’s modem to maximize the speed you are paying for.
Quick and Easy Setup
Unlike some WiFi systems, Orbi works with your Internet service provider right out of the box. You won’t need to change your current equipment to use the Orbi WiFi Home System. Orbi uses a single WiFi name (SSID) and with just a couple of clicks, your secure WiFi network will be ready in no time.
Routers. Not Just for Squares Anymore
Orbi’s sleek design and state-of-the-art technology steals the show. It gives your home a superior WiFi network that is both easy to setup and elegant to display.
Product Description NETGEAR Orbi WiFi System RBK50 - Wi-Fi system - 802.11a/b/g/n/ac - desktop
Device Type Wi-Fi system - mesh
Enclosure Type Desktop
Wi-Fi System Components Router, extender
Wi-Fi System Coverage Up to 5,000 sq.ft
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands)
Intelligent Assistant Alexa
Features MU-MIMO technology, beamforming technology, guest access, Circle Smart Parental Controls
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Dimensions (WxDxH) 16.3 cm x 7.87 cm x 20.3 cm
Weight 889 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR Orbi Router an...
£379.11
