This Orbi WiFi System comes with an Orbi Wi-Fi router and satellite that deliver unparalleled Wi-Fi coverage. It covers homes up to 6,000 square feet with strong Wi-Fi signals. Innovative Tri-band Wi-Fi helps maximize the Internet speeds available in your home.
Product Description | NETGEAR Orbi RBK23 - Wi-Fi system - 802.11a/b/g/n/ac - desktop | Device Type | Wi-Fi system | Enclosure Type | Desktop | Wi-Fi System Components | Router, 2 extenders | Wi-Fi System Coverage | Up to 6,000 sq.ft | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Features | Wi-Fi Protected Setup (WPS), MU-MIMO technology, beamforming technology, Backhaul Technology, FastLane3 technology, Circle with Disney | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 14.2 cm x 6.1 cm x 16.8 cm | Weight | 476 g |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA2-PSK |
Wi-Fi AC Rating | AC2200 |
Processor | 710 MHz |
RAM | 512 MB |
Flash Memory | 256 MB |
Line Properties | |
Line Coding Format | 256 QAM |
Internet of Things (IoT) | |
Intelligent Assistant Compatible | Google Assistant, Alexa |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 - on extender , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 - on extender |
Aerial | |
Aerial | Internal |
Antenna Qty | 4 |
Power | |
Power Device | External power adapter |
Installed Qty | 3 |
Miscellaneous | |
Cables Included | 1 x network cable - 1.98 m |
Dimensions & Weight | |
Width | 14.2 cm |
Depth | 6.1 cm |
Height | 16.8 cm |
Weight | 476 g |
