NetGear PAV12V AC/DC Power Adapter for Wireless-AC Access Points
£13.21
Delivery:
Standard: 1-3 working days
Product codes
Product Description NETGEAR - power adapter
Device Type Power adapter - external
Localisation United Kingdom
Output Voltage 12 V
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: BYLB 046110
£2.67
product
Ref: BYLB 046110
Accessories
Packaging
Functional
Software
Manuals
£2.67
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£13.21
