Netgear Powerline 1000 (PL1000)
Extend your wired Internet access to any room in your house using your existing electrical wiring. Just plug the Powerline 1000 into any electrical outlet then plug in your device into the adapter. It's that easy. With its high speed and Homeplug AV2 support, the Powerline 1000 adapter is perfect for connecting smart TVs, streaming players, and game consoles.
Whats in the box?
Key Features
Product Features
Product Description | NETGEAR Powerline PL1000 - powerline adapter kit - wall-pluggable | Device Type | Powerline adapter kit | Packaged Quantity | 2 (specifications are for single item) | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV) 2.0 | Data Transfer Rate | 1 Gbps | Compliant Standards | IEEE 802.3, HomePlug AV 2.0, IEEE 1901 | Power | AC 120/230 V | Dimensions (WxDxH) | 5.9 cm x 3.59 cm x 10 cm | Weight | 126 g | System Requirements | Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 | Localisation | United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Interfaces | 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 5 Watt |
Miscellaneous | |
Cables Included | 2 x network cable - 2 m |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 |
Dimensions & Weight | |
Width | 5.9 cm |
Depth | 3.59 cm |
Height | 10 cm |
Weight | 126 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - 90 days |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
