NETGEAR Pro GS728TPPv2 24 port Smart Rack-Mountable Switch
£533.25
Delivery:
Standard: 1-3 working days
Key features
  • Auto-Voice VLAN for fast and reliable deployment of VoIP
  • Auto-Video VLAN, following the same concept of Auto Voice, help speed up your deployment of IP-based surveillance systems
  • Static routing, helps route internal traffic for more efficient use of network resources
  • IGMP and MLD snooping, provides advanced multicast filtering
  • Comprehensive IPv6 management, QoS and ACL, ensuring investment protection and a smooth migration to IPv6-based networking
  • The presence of SFP ports provide necessary fiber uplinks, while dedicated SFP ports on many models further builds uplink redundancy
  • Type: Gigabit Ethernet
  • Ports: 24
  • Managed: Yes
  • POE: PoE+
Product codes
NETGEAR Smart Managed Pro Switches offer powerful L2 and L2+/Layer 3 Lite features, great PoE functionality, and enhanced performance and usability. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. These switches are optimized for network efficiency, operational cost savings, and ease of management. These switches are the ideal solution even for the most advanced small and medium organizations looking for the best combination of features, performance, and value.
Product Description NETGEAR Pro GS728TPPv2 - v2 - switch - 24 ports - smart - rack-mountable
Device Type Switch - 24 ports - L3 - smart
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 24 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE) PoE+
PoE Budget 380 W
Performance Bandwidth: 56 Gbps , Forwarding performance (64-byte packet size): 41.67 Mpps
Capacity ACL: 100 , ARP entries: 512 , VLANs supported: 256 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP multicast groups: 512
MAC Address Table Size 16K entries
Jumbo Frame Support 10KB
Routing Protocol Static IP routing
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
Features DHCP support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, DHCP snooping, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Multicast VLAN Registration (MVR), Generic Attribute Registration Protocol (GARP), GARP VLAN Registration Protocol (GVRP), Type of Service (ToS), DiffServ Code Point (DSCP) support, 2 fans, 1.5MB packet buffer, cable test, ICMP Router Discovery Protocol (IRDP), IGMP querier, Voice VLAN, Private VLAN, Guest VLAN, Denial of Service (DoS) protection, Weighted Round Robin (WRR), Auto VoIP, MAC lockdown
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 25.7 cm x 4.32 cm
Weight 4.11 kg
Localisation Europe
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£533.25
