We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The GS110TPP comes with a comprehensive set of features, such as enhanced VLAN and QoS, access control lists (ACL), 802.1x port authentication (MD5), rate limiting and IGMP snooping and many more, to provide businesses with networks that are geared for growth while ensuring performance and reliability. Both an intuitive web-browser GUI interface and smart control center, offer simple management, making it a snap to monitor switch performance, configure ports, even set up port trunks, VLANs, and traffic prioritization. With the fanless design and compact form factor, the GS110TPP offers quiet operation and is suitable for deployments in any type of environment, especially the ones which are sensitive to noise.
Product Description | NETGEAR GS110TPP - switch - 8 ports - smart | Device Type | Switch - 8 ports - smart | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE+) + 2 x 10/100/1000 (uplink) | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 120 W | Performance | Non-blocking switching throughput: 20 Gbps , Forwarding performance (64-byte packet size): 14.8 Mpps | Capacity | IPv4 routes (static): 32 , Packet buffer size: 512 KB , ACL: 100 , VLANs supported: 64 , IGMP multicast groups: 256 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 10KB | Routing Protocol | IGMPv2, IGMP, IGMPv3, MLD | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, IPv4, IPv6 | Features | Flow control, VLAN support, IGMP snooping, DoS attack prevention, store and forward, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, IPv4 support, fanless, LACP support, Energy Efficient Ethernet, 512KB packet buffer, loop prevention, static routing, Strict Priority (SP), Generic Attribute Registration Protocol (GARP), Generic VLAN Registration Protocol (GVRP), Denial of Service (DoS), cloud managed, VoIP support, DiffServ Code Point (DSCP) support, LLDP-MED, Weighted Round Robin (WRR), port trunking, security slot (Kensington security lock compatible) | Compliant Standards | IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az | Dimensions (WxDxH) | 23.6 cm x 10.1 cm x 2.7 cm | Weight | 640 g | Localisation | Europe | Manufacturer Warranty | Limited lifetime warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
Authentication Method | RADIUS, TACACS+ |
Processor | : 500 MHz |
RAM | 128 MB |
Flash Memory | 32 MB |
Status Indicators | Power, PoE, link/activity/speed, fault, cloud |
Expansion / Connectivity | |
Interfaces | 8 x 10/100/1000 Base-T RJ-45 PoE+ - 30 W , 2 x 10/100/1000 Base-T RJ-45 uplink |
Power | |
Power Device | External power adapter |
Installed Qty | 1 |
Miscellaneous | |
MTBF | 646,773 hours |
Dimensions & Weight | |
Width | 23.6 cm |
Depth | 10.1 cm |
Height | 2.7 cm |
Weight | 640 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime , Limited warranty - power supply - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
