We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This GBIC is built to insert into any one of the two built-in 10 GE SFP+ interfaces of GSM7328Sv2 and GSM7352Sv2, and into the 10GE SFP+ interface of AX743 adapter module for GSM73xxS/GSM73xxSv2. Once inserted (hot-swappable), the AXM761 10GBASE-LR SFP+ (LC connector) drives 10 Gigabit Ethernet up to 10 km distances with 9/125µm SMF single mode fiber cables, or up to 33 m distances with 62.5/125µm OM1 multimode fiber cables.
Product Description | NETGEAR ProSafe AXM762 - SFP+ transceiver module - 10 GigE | Device Type | SFP+ transceiver module | Form Factor | Plug-in module | Cabling Type | 10GBase-LR | Data Link Protocol | 10 GigE | Max Transfer Distance | 10 km | Designed For | NETGEAR GSM7228PS, GSM7252PS, GSM7328S, GSM7352S, M4300-28G-PoE+ |
General | |
Networking | |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 10GBase-LR |
Compatible Slots | 1 x SFP+ |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
