NetGear ProSafe 10GBASE-LR SFP+ LC GBIC Module
Lifetime warranty
£715.81
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Adds 10Gigabit Ethernet "long-reach" LC fiber connectivity to the standard SFP+ interfaces
  • Fits into the two built-in 10GE SFP+ interfaces of GSM72xxPS / GSM73xxS
  • Fits into the 10GE SFP+ interface of the SFP+ Adapter module AX743
  • Fits into standard 10 Gigabit SFP+ interfaces
  • LC connector
  • Drives 10 Gigabit Ethernet up to 10 km distances with 9/125 µm SMF single mode fiber cables
  • Drives 10 Gigabit Ethernet up to 300 m distances with 50/125 µm laser-optimized OM3 multimode fiber cables
  • Drives 10 Gigabit Ethernet up to 33m distances with 62.5/125 µm OM1 multimode fiber cables
  • Provides hot-swappable installation or removal
  • 10GBaseLR fiber technology is the same for XFP and SFP+: one Switch equipped with XFP 10GBase-LR LC connectivity can uplink to another Switch equipped with SFP+ 10GBase-LR LC connectivity using the same fiber
  • Type: Modules
  • Stock Status: In Stock
Product codes
This GBIC is built to insert into any one of the two built-in 10 GE SFP+ interfaces of GSM7328Sv2 and GSM7352Sv2, and into the 10GE SFP+ interface of AX743 adapter module for GSM73xxS/GSM73xxSv2. Once inserted (hot-swappable), the AXM761 10GBASE-LR SFP+ (LC connector) drives 10 Gigabit Ethernet up to 10 km distances with 9/125µm SMF single mode fiber cables, or up to 33 m distances with 62.5/125µm OM1 multimode fiber cables.
Product Description NETGEAR ProSafe AXM762 - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module
Form Factor Plug-in module
Cabling Type 10GBase-LR
Data Link Protocol 10 GigE
Max Transfer Distance 10 km
Designed For NETGEAR GSM7228PS, GSM7252PS, GSM7328S, GSM7352S, M4300-28G-PoE+
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear ProSafe 10GBAS...
£715.81
