NETGEAR ProSafe 16 Port 10/100 Desktop
LIFETIME WARRANTY
£142.95
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Affordable Power over Ethernet switching
  • Flexible
  • Plug and Play
  • Quiet and compact
  • Great value
  • Type: Fast Ethernet
  • Ports: 16
  • Data Transfer Rate: 100Mbps
  • Managed: No
  • POE: PoE
Product codes
The ProSafe FS116P provides power and data from a single point, using Power over Ethernet (PoE) over a single Cat-5 cable. The sixteen Fast Ethernet ports can be used for any 10/100 Mbps link and eight of these ports can supply industry-standard IEEE 802.3af power. Advanced auto-sensing algorithm gives power only to 802.3af end devices, so no need to worry about damaging proprietary PoE or non-PoE equipment. In addition, it discontinues the power when PoE devices are disconnected. Easy and reliable, the ProSafe FS116P automatically determines PoE requirements, speed, duplex, and cable type using AutoUplink.
The affordably priced ProSafe FS116P delivers PoE to any small business network that wants to simplify the installation of wireless access points and IP-based surveillance cameras. These devices are optimally installed on a ceiling or high on a wall, away from most electrical outlets. PoE eliminates the requirement for a dedicated electrical outlet to power these devices. This allows for flexibility in situating devices where AC power is difficult to access and lowers installation costs. Compact and flexible, the ProSafe FS116P is ideal for small business network that want to inexpensively use PoE to deploy wireless access points and IP-based network surveillance cameras.
Choose to plug in up to eight Ethernet or Fast Ethernet devices and mix in up to four 802.3af IP-based devices like wireless access points or IP-based network surveillance cameras. Place these 802.3af-compliant devices where they belong - high up on walls and ceiling for maximum coverage - or anywhere else you need them. Power and data are carried over standard Cat-5 cabling.
The standards-based ProSafe FS116P senses and adjusts for network speed and cabling type automatically, for easy integration into your existing 10/100 Ethernet network. For PoE, the switch automatically detects 802.3af-compliant devices, and supplies power as needed. Front panel LEDs keep you informed of switch and PoE status.
Engineered for compact convenience, it is only 1-inch high and 4-inches deep, with a durable metal case that is easily positioned on your desktop or a wall, using the included mounting hardware. The fan-less design quietly integrates in your small office environment.
With data switching and Power over Ethernet integrated into one unit, the FS116P saves space, reduces cables and eliminates the requirement for dedicated electrical outlets - lowering installation costs, simplifying installation of PoE-capable devices, and eliminating the need for electricians or extension cords. All in all a great benefit for a modest price.
Product Description NETGEAR FS116Pv2 - switch - 16 ports - unmanaged
Device Type Switch - 16 ports - unmanaged
Subtype Fast Ethernet
Ports 16 x 10/100 (PoE)
Power Over Ethernet (PoE) PoE
PoE Budget 70 W
Performance Bandwidth: 3.2 Gbps
MAC Address Table Size 8K entries
Features Flow control, auto-sensing per device, store and forward, Energy-Efficient Ethernet (EEE)
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x
Dimensions (WxDxH) 28.6 cm x 10.2 cm x 2.7 cm
Weight 830 g
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSafe 16 Por...
£142.95
