NetGear ProSafe 16 Port GE PoE Smart Switch
Lifetime warranty
£260.88
45 in stock
Delivery:
Standard: 1-3 working days
Key features
  • AutoSensing and autonegotiating capabilities for all ports
  • Auto Uplink on all ports to make the right connection
  • Automatic address learning function to build the packet-forwarding information table
  • The table contains up to 8K Media Access Control (MAC) addresses
  • Store-and-forward transmission to remove bad packets from the network
  • Full-duplex IEEE 802.3x pause frame flow control
  • Active flow control to minimize packet loss and frame drops
  • Half-duplex backpressure control
  • LEDs. Power LED, FAN Status LED, Max PoE LED, and LEDs for each port
  • Internal open frame power supply
  • Type: Gigabit Ethernet
  • Ports: 16
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: PoE+
Product codes
The GS516TP Gigabit Smart Switch is a state-of-the-art, high-performance, IEEE-compliant network solution designed for users who require many ports and want the power of gigabit connectivity to eliminate bottlenecks, boost performance, and increase productivity. The front panel of the switch has 16 twisted-paired ports that support nonstop 10/100/1000 networks.
Product Description NETGEAR GS516TP - switch - 16 ports - Managed - rack-mountable
Device Type Switch - 16 ports - L3 Lite - Managed
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE) + 8 x 10/100/1000
Power Over Ethernet (PoE) PoE+
PoE Budget 76 W
Performance Bandwidth: 32 Gbps
Capacity Static routes: 32 , Layer 2 multicast groups: 1000 , DHCP snooping entries: 1024
MAC Address Table Size 8K entries
Jumbo Frame Support 9KB
Routing Protocol IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP
Features Flow control, auto-sensing per device, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, Class of Service (CoS), 8MB packet buffer, 802.1x authentication, Type of Service (ToS), VoIP support, DiffServ Code Point (DSCP) support, administrator's password
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
Dimensions (WxDxH) 32.8 cm x 16.9 cm x 4.3 cm
Weight 2.213 kg
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear ProSafe 16 Por...
£260.88
