NETGEAR ProSafe 16-port Gigabit Ethernet Switch
LIFETIME WARRANTY
£80.59
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Each port delivers up to 2000Mbps of network speed (full duplex)
  • Fast, auto-switching and auto-sensing 10/100/1000Mbps Ethernet connection
  • 16 or 24 switched ports provide bandwidth for PCs, servers or switches
  • Auto Uplink automatically adjusts for straight-through or crossover cables
  • Plug and play - begins working as soon as it is powered on
  • Compact size for desktop or for mounting in a standard 19-inch rack
  • Type: Gigabit Ethernet
  • Ports: 16
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: [N/A]
Product codes
Take Gigabit to the Desktop
NETGEAR’s JGS500 Gigabit Switch Series gives your office network a megaboost of speed and capacity that is within your budget. With up to 48 Gbps of bandwidth, these 16- and 24-port switches can blast 2000 Mbps per port while their affordable prices enable you to put them everywhere. Use it to take Gigabit Ethernet directly to the desktop! Standards-based for easy integration of 10-, 100-, and 1000-Mbps devices, these unmanaged, rack-mountable switches feature 10/100/1000 automatic speed and full/half-duplex sensing plus Auto Uplink on every port. Users can take advantage of the their ability to deliver large amounts of multimedia, image, and video information in no time at all. Ideal for workgroups, labs, departments, or growing offices looking for oustanding performance at a low price.
High Capacity
1000-Mbps speeds and a switching capacity of up to 48 Gbps meet the performance needs for even the most bandwidth-hungry applications. The JGS500 series are perfect for graphics, multimedia, and other applications that have to move large files across the network quickly.
Affordable
Aggressive prices enable your workgroup, department or small network to ramp up to Gigabit speeds, even all the way to the desktop.
Flexible
Each port is equipped with automatic speed and duplex sensing, plus Auto Uplink to adjust for straight-through or crossover cables to make the right link. Standards-based design makes it easy to combine 10-, 100-, and 1000-Mbps devices on your network.
Convenient
Easy to set up and easy to use, these unmanaged switches have per port LED’s for effortless network monitoring. They are compact enough for the desktop but come with a rack-mount kit. They are also compatible with PC, Macintosh, Linux, and Unix operating systems.
Product Description NETGEAR JGS516v2 - switch - 16 ports - unmanaged - rack-mountable
Device Type Switch - 16 ports - unmanaged
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 16 x 10/100/1000
Performance Switching capacity: 32 Gbps
MAC Address Table Size 8K entries
Jumbo Frame Support 9KB
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Energy Efficient Ethernet, Type of Service (ToS)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Power AC 100/230 V (50 - 60 Hz)
Dimensions (WxDxH) 32.8 cm x 16.9 cm x 4.3 cm
Weight 1.47 kg
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
NETGEAR ProSafe 16-por...
£80.59
