NETGEAR ProSafe 24 Gigabit Stacking Kit
LIFETIME WARRANTY
£247.63
Delivery:
Standard: 1-3 working days
  • Type: Mounting Kits
  • Stock Status: In Stock
Product codes
This accessory module is built to insert into any one of the 4 high-speed module bays found on either the ProSAFE GSM7428S or ProSAFE GSM7352S. Once inserted, the high-speed module bay can then be utilized with standard 10GBASE-X XFP modules for fiber connectivity at 10Gbps speeds. Specifically, this adapter module accommodates the ProSAFE AXM75110GBASE-SR "Short Reach" or ProSAFE AXM752 10GBASE-LR "Long Reach" XFP optics modules. The AX741 is hot-swappable at any time into the switch and provides hot-swappable installation or removal of standard 10GBASE-X XFP optics modules.
ProSAFE AX742 24Gbps Stacking Kit
This accessory kit is utilized to connect two switches together in order to configure them into an operational stack of switches. The kit supplies 2 AX742 Stacking modules and a single high-capacity stacking cable. A minimum of a single kit is required to create a stack between two switches. A group of up to 8 switches can be interconnected to form a single stack by cascading the connections between switches. It is recommended that a final connection be established between the first and the last switch to create a loop topology. This provides two 24Gbps connections per switch within the stack. Once connected the stack operates as a 48Gbps resilient, self-healing, bi-directional ring.
Product Description NETGEAR ProSafe AX742 - expansion module
Device Type Expansion module
Packaged Quantity 2 (specifications are for single item)
Form Factor Plug-in module
Data Transfer Rate 24 Gbps
Manufacturer Warranty 5-year warranty
Designed For NETGEAR GSM7228PS, GSM7252PS, GSM7328Sv2, GSM7352Sv2; Next-Gen Edge Managed Switch M5300-28G, M5300-28GF3, M5300-52G
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSafe 24 Gig...
£247.63
