NETGEAR ProSafe 48-Port Gigabit L2 Managed Switch
LIFETIME WARRANTY
£458.53
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Full set of Layer 2+management features, including static routing
  • Flexible fiber connectivity enabled through four combination Small Form-factor Pluggable (SFP) gigabit interfaces
  • Type: Gigabit Ethernet
  • Ports: 48
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: [N/A]
Product codes
NETGEAR delivers wirespeed Gigabit performance and a full set of Layer 2 management features, as well as static routing with unsurpassed affordability. This next-generation, high-speed switch delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for Fast Ethernet switches and high-speed servers in demanding small networks. The non-blocking design offers full Gigabit throughput simultaneously to all 24 or 48 10/100/1000 ports to ensure reliable performance. Flexible fiber connectivity is enabled through four combination small form-factor pluggable (SFP) gigabit interfaces. Layer 2 management functionality delivers reliability, control, and availability. Static routing enables inter-VLAN routing and provides a faster network and more effective bandwidth management. Access control lists (L2-L4) provide robust security, while L2-L4 based QoS provides enhanced traffic management capabilities. The cost-effective NETGEAR ProSafe Gigabit L2 Managed Switch creates a more productive - and future-proof - network. With increasing bandwidth requirements from applications such as voice, video, database management, and other services that slow throughput and response time, you can unleash your network and enable maximum productivity with Gigabit Ethernet for today's high-performance environments.
Multiple NETGEAR fully managed switches can be managed via a single IP address. Optimize bandwidth, security, and control with full Layer 2 management capabilities. Network administrators can use any combination of these features to ensure uptime, availability, bandwidth and throughput.
Product Description NETGEAR GSM7248v2 - switch - 48 ports - Managed
Device Type Switch - 48 ports - Managed
Subtype Gigabit Ethernet
Ports 48 x 10/100/1000 + 4 x shared SFP
Performance Bandwidth: 96 Gbps
Capacity Virtual interfaces (VLANs): 1024 , Static routes: 32
MAC Address Table Size 8K entries
Jumbo Frame Support 9KB
Routing Protocol Static IP routing
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
Features Flow control, auto-negotiation, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, DiffServ support, manageable, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, DHCP snooping, Access Control List (ACL) support, Data prioritization (Qos) for VoIP applications, MLD snooping
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v
Power DC 12 V
Power Redundancy Yes
Dimensions (WxDxH) 44 cm x 20.5 cm x 4.3 cm
Weight 3.7 kg
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSafe 48-Por...
£458.53
