We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProSafe Gigabit stackable smart switch family is unique in delivering the scalability, reliability, and performance growing small and medium-sized businesses need in an affordable and easy-to-manage package. This stackable smart switch offers more flexibility and scalability that will make it easier and non-interruptive for growing businesses to expand their network capacity.
Product Description | NETGEAR Smart GS752TS - switch - 48 ports - Managed - rack-mountable | Device Type | Switch - 48 ports - Managed - stackable | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 48 x 10/100/1000 + 2 x combo Gigabit SFP + 4 x Gigabit SFP | Capacity | Virtual interfaces (VLANs): 256 | MAC Address Table Size | 16K entries | Routing Protocol | IGMPv2, IGMP, IGMPv3, MLD | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP | Features | Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, firmware upgradable, SNTP support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Quality of Service (QoS), MLD snooping, LLDP support, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, static routing | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az | Power | AC 120/230 V (50 - 60 Hz) | Dimensions (WxDxH) | 44 cm x 25.7 cm x 4.3 cm | Weight | 4.3 kg | Localisation | Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Max Units In A Stack | 6 |
RAM | 128 MB DDR SDRAM |
Flash Memory | 32 MB |
Status Indicators | Port transmission speed, power, PoE, link/activity, fan |
Expansion / Connectivity | |
Interfaces | 50 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC) |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Power Consumption Operational | 77 Watt |
Miscellaneous | |
Rack Mounting Kit | Included |
Compliant Standards | C-Tick, EN 60950, EN55022, VCCI Class A ITE, EN55024, UL 60950, CB, CCC, FCC Part 15 A |
Dimensions & Weight | |
Width | 44 cm |
Depth | 25.7 cm |
Height | 4.3 cm |
Weight | 4.3 kg |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
