An ideal companion to the rapidly emerging class of 10-gigabit servers, the NETGEAR ProSafe 52-port gigabit stackable smart switch is the smart switch with 10-gigabit connectivity - delivering maximum throughput in SMB networks for demanding tasks such as data replication and backup, virtualization, video on demand and high-volume transaction processing. At less than half the cost of a managed switch, the ProSafe 52-port gigabit smart switch provides 48 gigabit ports for connecting devices to the network, along with four 10 GE SFP+ ports for stacking or uplink to servers. The GS752TXS offers a rich enterprise-class feature set, including advanced traffic management and security, yet can be easily configured and monitored through a web-based graphical user interface.
With a rich set of Layer 2 management features, the GS752TXS is efficient, secure and ready for the future. Static routing allows for segmentation of the network, with internal routing through the switch - reserving the router for external traffic routing only, making the entire network more efficient. Dynamic VLAN assignment increases security by imposing consistent policy and user credentials across the network, regardless of where users connect. Support for MLD Snooping greatly increase network efficiency by forwarding multicast traffic to designated hosts only, rather than flooding multicast packets across all ports. The GS752TXS also comes with full IPv6 support, comprehensive security and advanced multicast management.
Product Description | NETGEAR Smart GS752TXS - switch - 48 ports - Managed | Device Type | Switch - 48 ports - Managed - stackable | Subtype | Gigabit Ethernet | Ports | 48 x 10/100/1000 + 4 x 10 Gigabit SFP+ | Performance | Bandwidth: 176 Gbps | Capacity | QoS hardware queues: 8 , Virtual interfaces (VLANs): 256 | MAC Address Table Size | 16K entries | Routing Protocol | IGMPv2, IGMP, IGMPv3, MLD | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c | Features | Layer 2 switching, VLAN support, IGMP snooping, DoS attack prevention, IPv6 support, SNTP support, DHCP snooping, Quality of Service (QoS), RADIUS support, MLD snooping, LLDP support | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3aq, IEEE 802.3az | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 25.7 cm x 4.3 cm | Weight | 4.5 kg | Localisation | Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop |
Max Units In A Stack | 6 |
Authentication Method | RADIUS, TACACS+ |
RAM | 128 MB DDR SDRAM |
Flash Memory | 32 MB |
Status Indicators | Power, link/activity, fan |
Expansion / Connectivity | |
Interfaces | 48 x 1000Base-T RJ-45 , 4 x SFP+ |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Rack Mounting Kit | Included |
Compliant Standards | C-Tick, EN 60950, EN55022, VCCI Class A ITE, EN55024, FCC Part 15 A |
Dimensions & Weight | |
Width | 44 cm |
Depth | 25.7 cm |
Height | 4.3 cm |
Weight | 4.5 kg |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
