We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProSAFE WC9500 High Capacity Wireless Controller is a scalable, high performance WLAN solution for centralized management of up to 200 ProSAFE wireless access points in a single wireless controller. Three WC9500 Wireless Controller can stack into a single cluster to support up to 600 Access Points, with a fourth WC9500 acting as a redundant backup. The supported AP’s extends from entry level single band WNAP210/WNAP320/WN370 APs to dual band business class WNDAP360/350, and premium grade 3x3 WNDAP660/620, and outdoor WND930 AP’s, and is also 802.11ac ready.
The WC9500 Wireless Controller is easy to configure with an intuitive user interface and setup wizard, comprehensive dashboard and monitoring statistics. Flexible enough to support a few dozen laptops to several thousand tablets, it delivers enterprise grade functionality for mid to large-sized organizations, but without the cost and complexity of big IT. The WC9500 comes fully equipped with enterprise grade features such as comprehensive wireless security (WPA, WPA2, Radius, LDAP, Rogue AP protection), guest access, and full networking functionality including embedded DHCP server, VLAN on wired and wireless networks support, to full Quality of Service differentiation. Additionally, with no recurring annual license fees: Simply pay as you grow.
Product Description | NETGEAR High Capacity Wireless Controller WC9500 - network management device | Device Type | Network management device | Form Factor | External - 1U | Localisation | Worldwide (excluding China) | Data Link Protocol | Gigabit Ethernet, 10 Gigabit Ethernet | Capacity | Manageable access points: 200 , Maximum number of access points (per cluster): 600 , BSSIDs: 144 , Concurrent stations per cluster: 36000 , Concurrent stations: 12000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512 | Power | AC 100/230 V | Power Redundancy | Yes | Dimensions (WxDxH) | 44 cm x 43 cm x 4.3 cm | Weight | 7.57 kg | Manufacturer Warranty | NETGEAR lifetime warranty | Designed For | NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930; Premium WAC740 |
General | |
Height (Rack Units) | 1U |
Width | 44 cm |
Depth | 43 cm |
Height | 4.3 cm |
Weight | 7.57 kg |
Networking | |
Form Factor | External |
Connectivity Technology | Wired |
Network / Transport Protocol | TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP |
Routing Protocol | CIDR |
Remote Management Protocol | SNMP 1, RMON, Telnet, SNMP 2c, HTTP, TFTP, SSH |
Status Indicators | Power, status, fan |
Features | Auto-sensing per device, auto-negotiation, load balancing, LDAP support, VLAN support, Syslog support, stackable, IPv6 support, SNTP support, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Access Control List (ACL) support, RADIUS support, roaming function, DHCP server, IPv4 support, rogue access point detection, tagged VLAN, Captive Portal |
Encryption Algorithm | DES, Triple DES, IKE, TKIP, WPA-PSK, AES-CCMP, AES-CCM, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, AES-CBC, 128-bit SSL, 1024-bit RSA, 2048-bit RSA, TLS 1.1, WEP |
Authentication Method | X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e |
Expansion / Connectivity | |
Interfaces | 2 x 10Gb Ethernet - SFP+ , 1 x 1000Base-T (management) - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A |
Miscellaneous | |
MTBF | 664,072 hours |
Power | |
Power Device | Internal power supply - hot-plug |
Installed Qty | 2 |
Max Supported Qty | 2 |
Voltage Required | AC 100/230 V |
Power Consumption Operational | 82.3 Watt |
Power Provided | 165 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
Designed For | NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930 , NETGEAR Premium WAC740 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
