NetGear ProSAFE 8-port 10/100/1000 PoE Smart Switch with 2 SF...
NetGear ProSAFE 8-port 10/100/1000 PoE Smart Switch with 2 SFP Ports
LIFETIME WARRANTY
Key features
  • Power-over-Ethernet (PoE)
  • PoE Plus
  • Traffic management
  • Advanced security with 802.1x and ACL
  • Auto voice and auto video
  • PoE power management
  • PoE timer
  • Centralized management via the Smart Control Center
Product codes
The Netgear ProSafe GS510TP provides a compact solution that fits nicely into a situation where low-port density is desired for specific areas or extension of the network. It comes with 8 PoE-capable Gigabit copper ports to connect to your PoE end devices and two additional dedicated Gigabit Fiber ports for uplinks with greater distance. Plus, with the PoE Plus support, GS510TP is able to provide sufficient power for those power-hungry devices with up to 30w per port with a total power budget of 130w on the switch. GS510TP is packed with powerful features capable of enhancing any type of business network.
Product Description NETGEAR ProSAFE GS510TP - switch - 8 ports - Managed - rack-mountable
Device Type Switch - 8 ports - L3 Lite - Managed
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE) + 2 x SFP
Power Over Ethernet (PoE) PoE+
PoE Budget 130 W
Performance Bandwidth: 20 Gbps
MAC Address Table Size 4K entries
Routing Protocol IGMPv2, IGMP, IGMPv3
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Features Flow control, auto-sensing per device, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, DHCP client, Management Information Base (MIB), 512KB packet buffer, 802.1x authentication, VoIP support, DiffServ Code Point (DSCP) support, administrator's password
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
Power AC 120/230 V (50 - 60 Hz)
Dimensions (WxDxH) 32.8 cm x 16.9 cm x 4.3 cm
Weight 1.68 kg
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear ProSAFE 8-port...
