NETGEAR ProSafe 8 Port 10/100 Fast Ethernet PoE Switch
LIFETIME WARRANTY
£61.99
48 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Flexible
  • Plug-and-Play
  • Quiet and compact
  • Great value
Product codes
The ProSafe FS108P provides power and data from a single point, using Power over Ethernet (PoE) over a single Cat-5 cable. The eight Fast Ethernet ports can be used for any 10/100 Mbps link and four of these ports can supply industry-standard IEEE 802.3af power. Advanced auto-sensing algorithm gives power only to 802.3af end devices, so no need to worry about damaging proprietary PoE or non-PoE equipment. In addition, it discontinues the power when PoE devices are disconnected. Easy and reliable, the ProSafe FS108P automatically determines PoE requirements, speed, duplex, and cable type using AutoUplink.
The affordably priced ProSafe FS108P delivers PoE to any small business network that wants to simplify the installation of wireless access points and IP-based surveillance cameras. These devices are optimally installed on a ceiling or high on a wall, away from most electrical outlets. PoE eliminates the requirement for a dedicated electrical outlet to power these devices. This allows for flexibility in situating devices where AC power is difficult to access and lowers installation costs. Compact and flexible, the ProSafe FS108P is ideal for small business network that want to inexpensively use PoE to deploy wireless access points and IP-based network surveillance cameras.
NETGEAR ProSAFE FS108P - switch - 8 ports
Switch - 8 ports
Subtype
Fast Ethernet
Ports
4 x 10/100 (PoE) + 4 x 10/100
Power Over Ethernet (PoE)
PoE
PoE Budget
53 W
Performance
Bandwidth: 1.6 Gbps
MAC Address Table Size
1K entries
Flow control, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward, 96KB packet buffer
IEEE 802.3u, IEEE 802.3i, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x
23.5 cm x 10.3 cm x 2.7 cm
690 g
Europe
NETGEAR lifetime warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSafe 8 Port...
£61.99
