The GS110TPv3 adds full 8 port PoE support for deployment of modern PoE devices. Cautious spender organizations can now deploy PoE devices connected to a cost effective switch, with a reasonable PoE power budget of 55W. Each port can provide up to 30 watts to power up connected devices. Fanless, the GS110TPv3 supports perfectly silent desktop operation or wall mounting.
Product Description | NETGEAR Smart GS110TPv3 - switch - 8 ports - smart | Device Type | Switch - 8 ports - smart | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE) + 2 x SFP | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 55 W | Performance | Switching fabric bandwidth: 20 Gbps , Forwarding performance (64-byte packet size): 14.8 Mpps | Capacity | Packet buffer size: 512 KB , ACL entries (ingress): 100 , VLANs supported: 64 , IPv4 routes (static): 32 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 10KB | Routing Protocol | IGMPv2, IGMP, IGMPv3, static IPv4 routing, MLDv2, MLD | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPv6 | Features | IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, MLD snooping, fanless, Link Aggregation Control Protocol (LACP), DHCP client, dual firmware images, loop prevention, tagged VLAN, cable test, LLDP-MED, protected ports, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), Advanced QoS, Unknown Storm Control, security slot (Kensington security lock compatible) | Compliant Standards | IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az | Power | DC 54 V | Dimensions (WxDxH) | 23.6 cm x 10.1 cm x 2.7 cm | Weight | 610 g | Localisation | Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
PoE Budget | 55 W |
Encryption Algorithm | TLS 1.2 |
Authentication Method | RADIUS, TACACS+ |
Processor | : 500 MHz |
RAM | 128 MB |
Flash Memory | 32 MB |
Status Indicators | Port status, PoE, link/activity/speed |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP |
Power | |
Power Device | External power adapter |
Voltage Required | DC 54 V |
Power Consumption Operational | 69.5 Watt |
Power Consumption Stand by | 4.3 Watt |
Miscellaneous | |
Included Accessories | Wall mounting kit |
MTBF | 1,200,041 hours |
Dimensions & Weight | |
Width | 23.6 cm |
Depth | 10.1 cm |
Height | 2.7 cm |
Weight | 610 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
