NetGear ProSafe 8x10/100/1000 SM GB Switch PoE
LIFETIME WARRANTY
£126.32
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • PoE power management
  • Advanced Quality of Service (QoS)
  • Usability enhancements
  • Type: Gigabit Ethernet
  • Ports: 8
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: PoE
Product codes
Joining NETGEAR's ProSafe family of smart switch with high performance and cost efficiency, this 10-port Gigabit smart switch is packed with powerful features capable of enhancing any type of business network. The GS110TP is designed for customers who need a low port density solution with the combination of Gigabit speed and PoE capability. The GS110TP comes with 8 dedicated 10/100/1000 Mbps copper ports to connect to your end devices and two additional Gigabit fiber ports for uplinks with greater distance. With PoE capability on all 8 copper ports, the GS110TP can automatically detect PoE on the end devices and dynamically manage power assignments and priority. It is capable of delivering up to 15.4 W of power to devices such as wireless access points, IP phones and IP cameras, providing flexibility and ease of deployment to your network.
The GS110TP comes with a comprehensive set of features, such as enhanced VLAN and QoS, access control lists (ACL), 802.1x port authentication, rate limiting and IGMP snooping and many more, to provide businesses with networks that are geared for growth while ensuring performance and reliability.
With the fanless design and compact form factor, the GS110TP offers quiet operation and is suitable for deployments in any type of environment, especially the ones which are sensitive to noise.
Product Description NETGEAR GS110TP - switch - 8 ports - Managed
Device Type Switch - 8 ports - Managed
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE) + 2 x SFP
Power Over Ethernet (PoE) PoE
PoE Budget 46 W
Performance Bandwidth (full duplex): 20 Gbps
MAC Address Table Size 4K entries
Jumbo Frame Support Yes
Routing Protocol IGMPv2, IGMP
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Features VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, SNTP support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, DHCP client, Management Information Base (MIB), 512KB packet buffer, Class of Service (CoS), 802.1x authentication, DiffServ Code Point (DSCP) support, administrator's password
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
Dimensions (WxDxH) 23.6 cm x 10.16 cm x 2.7 cm
Weight 700 g
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear ProSafe 8x10/1...
£126.32
