Your ports, where you want them
Today's networks have increasing numbers of devices attached to them. As wired devices proliferate, it can be difficult to easily and neatly place networked ports where you want them.
NETGEAR ProSAFE Click Switches™ address this issue head on.
These innovative Gigabit Ethernet switches come with an industry-first, bracket mounting system for easy installation. With a flexible and unique 1-2-3-4 click arrangement, it's easier than ever to enable optimal placement and cable management in locations where other switches will not go.
Vertical/side mount, Vertical/rear mount, Horizontal/side mount and Horizontal/rear mount.
Put an end to unsightly cables and switch placement challenges. Deliver a better way for customers to put their ports, where they want them. Available now, click here for your Click Switch from authorised NETGEAR channels.
Product Description | NETGEAR Plus GSS116E - switch - 16 ports - Managed | Device Type | Switch - 16 ports - Managed | Ports | 16 x 10/100/1000 | Performance | Bandwidth: 32 Gbps | Capacity | Virtual interfaces (VLANs): 128 , Layer 2 multicast groups: 128 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9KB | Remote Management Protocol | TFTP | Features | Flow control, network monitoring, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, vertical mounting, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), horizontal mounting, Jumbo Frames support, fanless, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, tagged VLAN, 4MB packet buffer, metal housing, Type of Service (ToS), DiffServ Code Point (DSCP) support | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3az | Dimensions (WxDxH) | 7 cm x 40.7 cm x 3.5 cm | Weight | 1.3 kg | Localisation | Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop |
Status Indicators | Port transmission speed, power, link/activity |
Expansion / Connectivity | |
Interfaces | 16 x 1000Base-T RJ-45 |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 8.4 Watt |
Miscellaneous | |
Included Accessories | Cable retaining straps, 1-2-3-4 mounting kit |
MTBF | 721,479 hours |
Compliant Standards | VCCI, C-Tick, cUL, EN 60950, EN55022, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, CISPR 22, EN50082-1, CCC, FCC Part 15 |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Dimensions & Weight | |
Width | 7 cm |
Depth | 40.7 cm |
Height | 3.5 cm |
Weight | 1.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime , Limited warranty - power supply - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
