NETGEAR ProSafe Dual Band Wireless-N Access Point
LIFETIME WARRANTY
£165.31
Delivery:
Key features
  • Concurrent duel bond operation on PoE power
  • Internal antennas optimized for maximum performance
  • Intuitive GUI for easy configuration
  • Up to 15x the speed and 10x the coverage of 802.11g networks
  • Concurrent operation in 2.4 GHz and 5 GHz radio band for maximum wireless throughput
  • Backward compatibility with 802.11a, 802.11g and 802.11b network devices
  • Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
  • Support for 802.3af PoE for optimal placement of access point
  • Up to 15x the speed and 10x the coverage of 802.11a, 802.11g networks
  • Operation in 5 GHz radio band to avoid interference from 802.11b or 802.11g network devices
  • Integrated 802.3af PoE eliminates extra cables and enables optimal placement of the access point
  • Comprehensive SNMP functionality for advanced network management
  • Deploy wireless coverage over large areas with point-to-point and point-to-multipoint bridging via Wireless Distribution System (WDS)
  • Plenum-rated for safe and convenient placement above drop-down ceilings
  • Metal case includes Kensington lock slot for anti-theft
  • Internal antennas factory-optimized for maximum RF performance
  • Antenna take-offs enable optional accessory antenna attachment for 2.4 GHz operations
Product codes
Advanced Speed and Range with Comprehensive Internet Security
With Concurrent dual-band operation, comprehensive security, and quality of service, the ProSAFE® WNDAP350 is the Wireless-N workhorse a growing SMB needs.
Performance
- Up to 15x the speed and 10x the coverage of 802.11a, 802.11g networks
- Operation in 5 GHz radio band to avoid interference from 802.11b or 802.11g network devices
- Concurrent operation in 2.4 GHz and 5 GHz radio band
- Support for 802.3af PoE for optimal placement of access point
Supreme Business Value
- Backward compatibility with 802.11a, 802.11g and 802.11b network devices
- Comprehensive SNMP functionality for advanced network management
- Deploy wireless coverage over large areas with point-to-point and point-to-multipoint bridging via Wireless Distribution System (WDS)
- Lifetime hardware warranty
- Metal case includes Kensington lock slot for anti-theft
Robust Security
- Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
- Optimal solution for deployment in hardened locations
Ease of Use
- Intuitive interface simplifies management
- Integrated 802.3af PoE eliminates extra cables and enables optimal placement of the access point
- Antenna take-offs enable optional accessory antenna attachment for 2.4 GHz operations
- Plenum-rated for safe and convenient placement above drop-down ceilings
NETGEAR Dual Band Wireless-N Access Point WNDAP350 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
UNIX, Apple MacOS, Linux, Microsoft Windows 98/ME/2000/XP/Vista
Power Over Ethernet (PoE) Supported
PoE
NETGEAR lifetime warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSafe Dual B...
£165.31
