NETGEAR ProSafe Dual Band Wireless-N Access Point
LIFETIME WARRANTY
Key features
  • Concurrent duel bond operation on PoE power
  • Internal antennas optimized for maximum performance
  • Intuitive GUI for easy configuration
  • Up to 15x the speed and 10x the coverage of 802.11g networks
  • Concurrent operation in 2.4 GHz and 5 GHz radio band for maximum wireless throughput
  • Backward compatibility with 802.11a, 802.11g and 802.11b network devices
  • Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
  • Support for 802.3af PoE for optimal placement of access point
  • Up to 15x the speed and 10x the coverage of 802.11a, 802.11g networks
  • Operation in 5 GHz radio band to avoid interference from 802.11b or 802.11g network devices
  • Integrated 802.3af PoE eliminates extra cables and enables optimal placement of the access point
  • Comprehensive SNMP functionality for advanced network management
  • Deploy wireless coverage over large areas with point-to-point and point-to-multipoint bridging via Wireless Distribution System (WDS)
  • Plenum-rated for safe and convenient placement above drop-down ceilings
  • Metal case includes Kensington lock slot for anti-theft
  • Internal antennas factory-optimized for maximum RF performance
  • Antenna take-offs enable optional accessory antenna attachment for 2.4 GHz operations
Product codes
Advanced Speed and Range with Comprehensive Internet Security
With Concurrent dual-band operation, comprehensive security, and quality of service, the ProSAFE® WNDAP350 is the Wireless-N workhorse a growing SMB needs.
Performance
- Up to 15x the speed and 10x the coverage of 802.11a, 802.11g networks
- Operation in 5 GHz radio band to avoid interference from 802.11b or 802.11g network devices
- Concurrent operation in 2.4 GHz and 5 GHz radio band
- Support for 802.3af PoE for optimal placement of access point
Supreme Business Value
- Backward compatibility with 802.11a, 802.11g and 802.11b network devices
- Comprehensive SNMP functionality for advanced network management
- Deploy wireless coverage over large areas with point-to-point and point-to-multipoint bridging via Wireless Distribution System (WDS)
- Lifetime hardware warranty
- Metal case includes Kensington lock slot for anti-theft
Robust Security
- Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
- Optimal solution for deployment in hardened locations
Ease of Use
- Intuitive interface simplifies management
- Integrated 802.3af PoE eliminates extra cables and enables optimal placement of the access point
- Antenna take-offs enable optional accessory antenna attachment for 2.4 GHz operations
- Plenum-rated for safe and convenient placement above drop-down ceilings
Product Description NETGEAR Dual Band Wireless-N Access Point WNDAP350 - radio access point
Device Type Radio access point
Form Factor External
Localisation United Kingdom
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
OS Required UNIX, Apple MacOS, Linux, Microsoft Windows 98/ME/2000/XP/Vista
Power Over Ethernet (PoE) Supported PoE
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSafe Dual B...
