NetGear ProSafe GS116E Plus Switch 16 Port Gigabit Ethernet
LIFETIME WARRANTY
£79.30
19 in stock
Delivery:
Standard: 1-3 working days
  • Type: Gigabit Ethernet
  • Ports: 16
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: No
Product codes
The Prosafe Plus switch is an upgrade to unmanaged switch which can only Plug-N-Play, and is not configurable. Prosafe Plus switch gives user the flexibility to configure certain static layer 2 settings to better fit their needs. The GS116E is a 16-port Gigabit switch.
GS116E supports loop detection. When a loop is detected, the both LED on the affected port will blink at a constant speed with roughly 1 every second. Dos is a form of attack on computer network resources. The Auto Dos feature of GS116E would automatically block malicious packets such as source IP equals destination IP.
Product Description NETGEAR Plus GS116Ev2 - switch - 16 ports - Managed
Device Type Switch - 16 ports - Managed
Subtype Gigabit Ethernet
Ports 16 x 10/100/1000
Jumbo Frame Support Yes
Remote Management Protocol HTTP
Features Flow control, auto-negotiation, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, Quality of Service (QoS), reset button, loop prevention
Dimensions (WxDxH) 28.6 cm x 10.1 cm x 1.59 cm
Weight 0.84 kg
Localisation United Kingdom
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear ProSafe GS116E...
£79.30
