The NETGEAR ProSAFE Gigabit Smart Managed switches offer powerful Layer 3 Lite features with enhanced performance and usability. They are purposely designed for the future where increased traffic and application-oriented tasks demands more intelligence at the edge, higher reliability and improved network efficiency on top of operational cost savings and ease of management.
Product Description | NETGEAR Smart GS748T - V5 - switch - 48 ports - Managed - rack-mountable | Device Type | Switch - 48 ports - L3 Lite - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 48 x 10/100/1000 + 2 x Gigabit SFP + 2 x combo Gigabit SFP | Performance | Bandwidth: 100 Gbps | Capacity | Virtual interfaces (VLANs): 256 , ACL entries: 100 , Static routes: 32 , Layer 2 multicast groups: 512 , ARP entries: 512 , Priority queues per port: 8 | MAC Address Table Size | 16K entries | Jumbo Frame Support | 9KB | Routing Protocol | IGMPv2, IGMP, IGMPv3, MLDv2, MLD | Remote Management Protocol | SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP | Features | Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, MLD snooping, Dynamic ARP Inspection (DAI), LLDP support, DHCP client, Energy Efficient Ethernet, Strict Priority Queuing (SPQ), static routing, 802.1x authentication, Type of Service (ToS), VoIP support, DiffServ Code Point (DSCP) support, cable test, administrator's password, ARP inspection | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az | Dimensions (WxDxH) | 44 cm x 25.7 cm x 4.3 cm | Weight | 3.46 kg | Localisation | Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop, rack-mountable 1U |
Encryption Algorithm | SSL, TLS 1.0 |
Authentication Method | RADIUS, TACACS+ |
Status Indicators | Port transmission speed, link/activity |
Expansion / Connectivity | |
Interfaces | 48 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP , 2 x 1000Base-X SFP uplink |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 41.4 Watt |
Miscellaneous | |
Rack Mounting Kit | Included |
MTBF | 390,728 hours |
Compliant Standards | cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, TLS v1.0 |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Dimensions & Weight | |
Width | 44 cm |
Depth | 25.7 cm |
Height | 4.3 cm |
Weight | 3.46 kg |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
