NETGEAR ProSafe JGS524 - Switch - 24 ports
LIFETIME WARRANTY
£119.92
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Each port delivers up to 2000Mbps of network speed (full duplex)
  • Fast, auto-switching and auto-sensing 10/100/1000Mbps Ethernet connection
  • 16 or 24 switched ports provide bandwidth for PCs, servers or switches
  • Auto Uplink automatically adjusts for straight-through or crossover cables
  • Plug and play - begins working as soon as it is powered on
  • Compact size for desktop or for mounting in a standard 19-inch rack
  • Secure, durable metal housing includes a Kensington locking slot for theft prevention
  • Honors TOS/802.1p prioritization
  • Up to 50% lower power consumption
  • Auto power-down mode saves energy when port is unused
  • Auto green mode detects cable length and adjusts power usage to save energy
  • Packaging manufactured with at least 80% recycled materials
  • Type: Gigabit Ethernet
  • Ports: 24
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: [N/A]
Product codes
The affordable price of NETGEAR’s JGS524 enables you to cost-effectively deliver Gigabit Ethernet networking speeds across your entire office network – even directly to the desktop. With up to 48 Gbps of bandwidth, this 24-port switch can send 2000 Mbps per port. Network users can take advantage of the their ability to send and receive large amounts of multimedia, image and video information in no time at all. The JGS524 is ideal for teams, departments or growing offices requiring outstanding performance at a low price.
-Gigabit speeds meet performance needs of bandwidth hungry applications. -Easy integration of 10, 100, and 1000 Mbps devices. -Automatic speed and full/half-duplex sensing on every port. -Auto Uplink™ on every port to ensure correct link for different cables. -LED’s make network monitoring easy. -Compact enough for desktop, but comes with a rack mount kit. -Compatible with PC, Macintosh, Linux and Unix operating systems.
Product Description NETGEAR JGS524v2 - switch - 24 ports - unmanaged - rack-mountable
Device Type Switch - 24 ports - unmanaged
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 24 x 10/100/1000
Performance Switching capacity: 48 Gbps
MAC Address Table Size 8K entries
Jumbo Frame Support 9KB
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Energy Efficient Ethernet, Type of Service (ToS)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Power AC 100/230 V (50 - 60 Hz)
Dimensions (WxDxH) 32.8 cm x 16.9 cm x 4.3 cm
Weight 1.65 kg
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSafe JGS524...
£119.92
