We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Need a quantum leap in office network capability? NETGEAR delivers an effective solution--the JFS524. This unmanaged 10/100 Mbps Fast Ethernet switch provides expanded connectivity for small office networks so users no longer have to compete with each other for bandwidth. All of the essential features - automatic speed and full/half duplex sensing, 200 Mbps throughput per port, Auto Uplink are included, but at an economical price that a value-conscious business owner cannot ignore.
Frugal and Skillful
Twenty-four ports of speed and capacity at a modest price, with no compromising on quality--that's what you can expect from NETGEAR's hardworking JFS524. Switched 10/100 Mbps ports provide private bandwidth for PCs, servers, or hubs and support 200 Mbps of throughput. Each port delivers 200 Mbps of network speed in full-duplex mode.
Alert and Obliging
Ever-vigilant, the JFS524 begins to operate as soon as it's powered on - with no configuration required. All 24 ports deliver automatic speed and full/half duplex sensing, plus Auto Uplink, which adjusts for straight-through or crossover cables to make the right link. This rugged metal unit is conveniently compact for an uncluttered desktop or easy rack mounting. And it lets you easily intermix 10 and 100 Mbps devices within your unmanaged network.
Performance (64 byte packets)
Store-and-forward packet switching
Forward rate (10 Mbps) 14,800 packet per sec.
Forward rate (100 Mbps) 148,000 packet per sec.
Latency (10 to 100 Mbps) 20 usec max
MAC addresses 4,000
Queue buffer KBytes 320
Mean time between failures (MTBF): 110,000 hours (13 years)
Box Contains
ProSAFE 24-port 10/100 Fast Ethernet Switch
Rack-mount kit
Power cord
Installation guide
Product Description | NETGEAR 24-Port 10/100 Fast Ethernet Switch JFS524v2 - switch - 24 ports - unmanaged - rack-mountable | Device Type | Switch - 24 ports - unmanaged | Enclosure Type | Rack-mountable | Subtype | Fast Ethernet | Ports | 24 x 10/100 | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 28 cm x 12.6 cm x 4.4 cm | Weight | 1 kg | Localisation | Europe |
General | |
Enclosure Type | Desktop, rack-mountable |
Status Indicators | Port status, power |
Expansion / Connectivity | |
Interfaces | 24 x 100Base-TX RJ-45 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 4 Watt |
Miscellaneous | |
Compliant Standards | FCC Class A certified, CB, CCC, UL 60950-1, C-Tick Class A, VCCI Class A |
Dimensions & Weight | |
Width | 28 cm |
Depth | 12.6 cm |
Height | 4.4 cm |
Weight | 1 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
