We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The NETGEAR WAC720 ProSAFE Wireless Access Point is a high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2 Gbps (300 Mbps for 2.4GHz and 867 Mbps 802.11ac for 5GHz) with standalone and Ensemble management for centralized group management of up to 10 APs. WAC720 Business AP operates in either standalone mode with an intuitive user interface or in Ensemble mode for centralized group management of up to 10 APs. It is perfectly positioned for customers demanding high throughput, ultra-superior performance, and extensive coverage deployment for Small and Medium Enterprises, K-12, and Hospitalities.
Product Description | NETGEAR Business 2 x 2 Dual Band Wireless-AC Access Point WAC720 - radio access point - Wi-Fi 5 | Device Type | Radio access point | Form Factor | External | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Performance | Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps | Included Accessories | Wall mounting kit, ceiling mounting kit | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 19.7 cm x 19.7 cm x 4 cm | Weight | 726 g | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Width | 19.7 cm |
Depth | 19.7 cm |
Height | 4 cm |
Weight | 726 g |
Networking | |
Connectivity Technology | Wired |
Network / Transport Protocol | Bonjour |
Remote Management Protocol | SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI |
Status Indicators | Power, LAN, wireless, link/activity |
Features | VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, LLDP support, 802.1x authentication, Transmit Power Control (TPC) |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2 |
Authentication Method | RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP) |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac |
Aerial | |
Antenna | External detachable and internal |
Expansion / Connectivity | |
Interfaces | 1 x console - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 2 x aerial - RP-SMA |
Miscellaneous | |
Cables Included | 1 x network cable |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
