General |
Device Type |
Radio access point |
Width |
19.7 cm |
Depth |
19.7 cm |
Height |
4 cm |
Weight |
726 g |
Networking |
Form Factor |
External |
Connectivity Technology |
Wired |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Network / Transport Protocol |
Bonjour |
Remote Management Protocol |
SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI |
Frequency Band |
2.4 GHz, 5 GHz |
Performance |
Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps |
Status Indicators |
Power, LAN, wireless, link/activity |
Features |
VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, LLDP support, 802.1x authentication, Transmit Power Control (TPC) |
Encryption Algorithm |
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2 |
Authentication Method |
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP) |
Compliant Standards |
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac |
Aerial |
Antenna |
External detachable and internal |
Expansion / Connectivity |
Interfaces |
1 x console - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 2 x aerial - RP-SMA |
Miscellaneous |
Included Accessories |
Wall mounting kit, ceiling mounting kit |
Cables Included |
1 x network cable |
Power |
Power Over Ethernet (PoE) Supported |
PoE |
Manufacturer Warranty |
Service & Support |
Limited warranty - lifetime |
