Manage thousands of users with one smart and easy controller.
Exceptional ease-of-use. Best-in-class performance. A full-featured, reliable Wireless LAN architecture. In short, the WC7520 is the smart, easy choice to meet the demands of mid-size organizations with thousands of users.
Reliable, Secure and Scalable Wireless Controller for Mid-sized Businesses, Schools and Hospitals
The NETGEAR ProSAFE® Wireless Controller WC7520 offers a high-performance, fully-featured, yet extremely affordable, Wireless LAN architecture to meet the demands of medium-sized businesses, schools, and hospitals with thousands of users.
Performance
Scalability
Business Value
Ease of Use
Product Description | NETGEAR WC7500 - wireless network management device | Device Type | Wireless network management device | Form Factor | External - 1U | Localisation | Worldwide (excluding China) | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, PPP | Capacity | Manageable access points: 10 , Maximum number of access points: 15 , BSSIDs: 144 , Concurrent stations: 2000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512 | Power | AC 100/230 V | Dimensions (WxDxH) | 44 cm x 26.2 cm x 4.3 cm | Weight | 3.6 kg | Manufacturer Warranty | NETGEAR lifetime warranty | Designed For | NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930; Premium WAC740 |
General | |
Height (Rack Units) | 1U |
Width | 44 cm |
Depth | 26.2 cm |
Height | 4.3 cm |
Weight | 3.6 kg |
Networking | |
Form Factor | External |
Connectivity Technology | Wired |
Network / Transport Protocol | TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP |
Routing Protocol | CIDR |
Remote Management Protocol | SNMP 1, SNMP 2, RMON, Telnet, HTTP, TFTP, SSH |
Features | Auto-sensing per device, DHCP support, auto-negotiation, load balancing, VLAN support, IPv6 support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), IPv4 support, rogue access point detection, Management Information Base (MIB), rate limit |
Encryption Algorithm | DES, Triple DES, RC4, AES, IKE, SSL, TKIP, WPA, PKI, AES-CCMP, AES-CCM, WPA2-PSK, WPA2-Enterprise, AES-CBC, TLS 1.1, WEP |
Authentication Method | RADIUS, X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A |
Miscellaneous | |
MTBF | 664,072 hours |
Power | |
Voltage Required | AC 100/230 V |
Power Consumption Operational | 13 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days , Technical support - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
Designed For | NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930 , NETGEAR Premium WAC740 |
