NetGear ProSAFE WN370 Wall Mount Wireless-N Access Point
LIFETIME WARRANTY
£119.02
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Small form factor and inconspicuous appearance
  • Fast installation and PoE powered
  • Flexible and easy deployment
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 300Mbps
  • Protocol: IEEE 802.11ac (draft 2.0), IEEE 802.11b, IEEE 802.11g
  • Compatibility: Mac, PC
Product codes
Affordable, wired and wireless (802.11n single band 2.4 GHz) Access Point for small and medium hotels and K-12 dormitories. Sleek, elegant, and compact design allows AP to be deployed in an inconspicuous manner. Can be install in less than 5 minutes with a non- technical personnel and the Access Point is powered by Power Over Ethernet (1Gbps) to reduce cabling cost and time for deployments. WN370 comes with 4 (100Mbsp) Ethernet data ports and one Voice pass through voice port for connectivity of digital phones that requires native access to an in-house PBX system. It has centralized management with WC7600 Wireless Controllers for automatic RF and power tuning with guest access captive portal and comprehensive wireless securities.
Product Description NETGEAR WN370 - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11g, IEEE 802.11ac (draft 2.0)
Frequency Band 2.4 GHz
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 9.31 cm x 13.52 cm x 2.59 cm
Weight 218 g
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear ProSAFE WN370...
£119.02
