NETGEAR ProSAFE XS708T 10GBase 8 Port Switch
£533.16
Delivery:
Standard: 1-3 working days
Key features
  • Advanced VLAN features such as Protocol-based VLAN, MAC-based VLAN and 802.1x Guest VLAN
  • Advanced QoS with L2 / L3 / L4 awareness and 8 priority queues
  • IPv4 and IPv6 static routing
  • Private VLAN
  • Dynamic VLAN assignment
  • IGMP and MLD snooping
  • Advanced security
  • IPv6 for management, QoS and ACL
  • Type: 10 Gigabit Ethernet
  • Ports: 8
  • Managed: Yes
  • Stock Status: In Stock
Product codes
The XS708T 10-Gigabit Ethernet Smart Managed Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS708T is a powerful Smart Managed Switch that includes 8 ports of 10-Gigabit connectivity (8 copper with 2 shared combo copper/SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS708T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS708T is ideal for smaller workgroups that need high-bandwidth for sharing, collaborating, editing, and publishing high-density content like video or animation.
Product Description NETGEAR ProSAFE XS708T - switch - 8 ports - smart - rack-mountable
Device Type Switch - 8 ports - L3 Lite - smart
Enclosure Type Rack-mountable 1U
Subtype 10 Gigabit Ethernet
Ports 8 x 10GBase-T + 2 x shared 10 Gigabit SFP+
Performance Switching fabric bandwidth: 160 Gbps , Forwarding performance (64-byte packet size): 119 Mpps
Capacity ACL: 100 , Virtual interfaces (VLANs): 512 , IGMP groups: 512 , IPv4 routes: 32 , IPv6 routes: 32 , Priority queues per port: 8 , ARP entries: 738 , DHCP snooping entries: 8000
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol Static IPv4 routing, static IPv6 routing
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Features Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, Dynamic ARP Inspection (DAI), reset button, LACP support, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Strict Priority Queuing (SPQ), 2MB packet buffer, Class of Service (CoS), 802.1x authentication, Type of Service (ToS), DiffServ Code Point (DSCP) support, cable test, layer 2+ switching
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
Dimensions (WxDxH) 44 cm x 20.4 cm x 4.3 cm
Weight 2.61 kg
Localisation Latin America, North America, Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSAFE XS708T...
£533.16
