NETGEAR ProSAFE XS728T 28 Port 10GB Smart Switch
£1,797.86
Delivery:
Standard: 1-3 working days
Key features
  • Up to 3MB packet buffer memory (dynamically shared across only used ports)
  • 560 Gbps non-blocking fabric (bandwidth)
  • 8 Priority queues
  • Weighted Round Robin (WRR) priority queuing
  • Up to 32K Media Access Control (MAC) addresses with 48-bit MAC address
  • Up to 1024 Multicast groups
  • Up to 64 static IPv4 and IPv6 routes; up to 512 routed VLANs
  • 1024 ARP Cache entries
  • Up to 8K DHCP snooping bindings
  • Up to 164 shared rules for MAC, IP and IPv6 ACLs
  • Jumbo frames up to 10K packet size supported
  • Type: 10 Gigabit Ethernet
  • Ports: 28
  • Managed: Yes
  • Stock Status: In Stock
Product codes
The XS728T 10-Gigabit Ethernet Smart Managed Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS728T is a powerful Smart Managed Switch that includes 24 ports of 10-Gigabit connectivity (24 copper with 4 dedicated 10-Gigabit SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS728T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS728T is ideal for is ideal for expanding network capacity, removing performance bottlenecks and/or support of premise expansion needs.
Product Description NETGEAR XS728T - switch - 28 ports - smart - rack-mountable
Device Type Switch - 28 ports - L3 Lite - smart
Enclosure Type Rack-mountable 1U
Subtype 10 Gigabit Ethernet
Ports 24 x 10GBase-T + 4 x 10 Gigabit SFP+
Performance Switching fabric bandwidth: 560 Gbps
Capacity ACL: 164 , Virtual interfaces (VLANs): 512 , IGMP groups: 512 , IPv4 routes: 64 , IPv6 routes: 64 , Priority queues per port: 8 , ARP entries: 1024 , DHCP snooping entries: 1000
MAC Address Table Size 16K entries
Jumbo Frame Support 10KB
Routing Protocol IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Features Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, IPv4 support, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, static routing, Class of Service (CoS), 802.1x authentication, Type of Service (ToS), DiffServ Code Point (DSCP) support, 4 fans, 3MB packet buffer, cable test, administrator's password, layer 2+ switching
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
Power AC 120/230 V
Dimensions (WxDxH) 44 cm x 31 cm x 4.3 cm
Weight 5.04 kg
Localisation Latin America, North America, Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR ProSAFE XS728T...
£1,797.86
