We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
There's never been Wi-Fi like it. The Nighthawk X6 AC3200 Router with breakthrough Tri-Band Wi-Fi technology was built to connect to each and every device in your home - automatically and simultaneously. Laptops, tablets, phones, TVs, game consoles, music streamers, cameras - if it's Wi-Fi enabled, it's X6 accelerated. With a massive combined wireless speed of up to 3.2Gbps, 3 Wi-Fi bands and Smart Connect intelligence, every device is assigned the fastest Wi-Fi connection possible and optimized for maximum speed.
Product Description | NETGEAR Nighthawk X6 - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 3.2 Gbps | Remote Management Protocol | HTTP | Features | Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, firmware upgradable, Wi-Fi Protected Setup (WPS), ReadySHARE, Push ‘N’ Connect button, DLNA Media Server, Beamforming+, Circle Smart Parental Controls | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 29.55 cm x 22.68 cm x 5.45 cm | Weight | 1.1 kg | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8 | Localisation | United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA-PSK, WPA2-PSK |
Processor | 1 GHz |
RAM | 256 MB |
Flash Memory | 128 MB |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A |
Aerial | |
Aerial | External integrated |
Antenna Qty | 6 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
Software Included | NETGEAR Genie |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8 |
Dimensions & Weight | |
Width | 29.55 cm |
Depth | 22.68 cm |
Height | 5.45 cm |
Weight | 1.1 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
