NetGear R8000-100UKS Nighthawk X6 4port AC3200 Wifi Router
£197.43
Delivery:
Standard: 1-3 working days
Key features
  • Get the fastest Wi-Fi speed available - up to 3.2Gbps
  • Tri-Band Wi-Fi delivers more Wi-Fi for more devices
  • 6 high performance antennas for maximum range
  • Smart-connect designates slower and faster devices to separate Wi-Fi bands
  • Dual core processor with 3 offload processors
  • Beamforming+ improves wireless range and reliability
  • Type: Wireless router
  • Connection Type: DSL (Cable)
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
  • Speed: 3.2Gbps
  • Rackmount or External: External
Product codes
There's never been Wi-Fi like it. The Nighthawk X6 AC3200 Router with breakthrough Tri-Band Wi-Fi technology was built to connect to each and every device in your home - automatically and simultaneously. Laptops, tablets, phones, TVs, game consoles, music streamers, cameras - if it's Wi-Fi enabled, it's X6 accelerated. With a massive combined wireless speed of up to 3.2Gbps, 3 Wi-Fi bands and Smart Connect intelligence, every device is assigned the fastest Wi-Fi connection possible and optimized for maximum speed.
Product Description NETGEAR Nighthawk X6 - wireless router - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 3.2 Gbps
Remote Management Protocol HTTP
Features Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, firmware upgradable, Wi-Fi Protected Setup (WPS), ReadySHARE, Push ‘N’ Connect button, DLNA Media Server, Beamforming+, Circle Smart Parental Controls
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Dimensions (WxDxH) 29.55 cm x 22.68 cm x 5.45 cm
Weight 1.1 kg
System Requirements UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
Localisation United Kingdom
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear R8000-100UKS N...
£197.43
