NetGear S3300 28-port Stackable POE Smart Switch W/10G
£678.36
Delivery:
Standard: 1-3 working days
Key features
  • Auto Voice VLAN for easy development of VoIP
  • Auto Video for simple deployment of IP surveillance
  • Static routing, helps to route internal traffic for more efficient use of network resources
  • IGMP and MLD snooping, providing advanced multicast filtering
  • Extensive PoE+ capabilities extendable to 1,440W with supplemental RPS solution
  • Solid performance with non-blocking architecture, 8K MAC addresses, 256 VLANs, 480 shared ACL entries, 32 static routes, and 1,024 Multicast Groups
  • Type: Gigabit Ethernet
  • Ports: 28
  • Data Transfer Rate: 10Gbps
  • Managed: Yes
  • POE: PoE+
Product codes
The ProSAFE S3300 Switch series is a new generation of Gigabit Stackable Smart Switches, inclusive of 4 dedicated 10G ports for uplinks and/or stacking between other S3300 switches. As SMBs produce and consume more data, Gigabit to the desktop increasingly needs to be underpinned with 10GbE connectivity to the core to ensure a consistent, seamless user experience. This new generation of switches provides SMB customers with the most cost-effective 10G connections between their Gigabit access layer switches and aggregation layer 10G switches and Routers. The ProSAFE S3300 Smart Series is the blueprint for a dependable future-proof network. From Greenfield network requirements to network refresh projects, the series sets new standards in defining flexibility and choice for SMBs looking to leverage reliable, future proof technologies at affordable price points.
Product Description NETGEAR S3300-28X-PoE+ - switch - 28 ports - smart - rack-mountable
Device Type Switch - 28 ports - smart - stackable
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 24 x 10/100/1000 (PoE+) + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
Power Over Ethernet (PoE) PoE+
PoE Budget 195 W
Performance Bandwidth: 128 Gbps
Capacity VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol Static IPv4 routing
Remote Management Protocol SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
Features Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), DHCP client, Energy Efficient Ethernet, dual firmware images, Strict Priority Queuing (SPQ), Class of Service (CoS), IP source guard
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
Power AC 100/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 25.7 cm x 4.3 cm
Weight 3.77 kg
Localisation Latin America, North America, Europe
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear S3300 28-port...
£678.36
