We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The ProSAFE S3300 Switch series is a new generation of Gigabit Stackable Smart Switches, inclusive of 4 dedicated 10G ports for uplinks and/or stacking between other S3300 switches. As SMBs produce and consume more data, Gigabit to the desktop increasingly needs to be underpinned with 10GbE connectivity to the core to ensure a consistent, seamless user experience. This new generation of switches provides SMB customers with the most cost-effective 10G connections between their Gigabit access layer switches and aggregation layer 10G switches and Routers. The ProSAFE S3300 Smart Series is the blueprint for a dependable future-proof network. From Greenfield network requirements to network refresh projects, the series sets new standards in defining flexibility and choice for SMBs looking to leverage reliable, future proof technologies at affordable price points.
Product Description | NETGEAR Smart S3300-28X - switch - 28 ports - smart - rack-mountable | Device Type | Switch - 28 ports - smart - stackable | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 24 x 10/100/1000 + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+ | Performance | Bandwidth: 128 Gbps | Capacity | VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8 | MAC Address Table Size | 16K entries | Jumbo Frame Support | 9KB | Routing Protocol | Static IPv4 routing | Remote Management Protocol | SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI | Features | Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), DHCP client, Energy Efficient Ethernet, dual firmware images, Strict Priority Queuing (SPQ), Class of Service (CoS), IP source guard | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA | Power | AC 100/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 25.7 cm x 4.3 cm | Weight | 3.14 kg | Localisation | Latin America, North America, Europe | Manufacturer Warranty | Limited lifetime warranty |
General | |
Max Units In A Stack | 6 |
Authentication Method | RADIUS, TACACS+ |
Processor | : 800 MHz |
RAM | 512 MB |
Flash Memory | 128 MB |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 100/230 V (50/60 Hz) |
Power Consumption Operational | 28.18 Watt |
Features | Redundant Power System (RPS) connector |
Miscellaneous | |
Rack Mounting Kit | Included |
MTBF | 278,559 hours |
Compliant Standards | CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A |
Dimensions & Weight | |
Width | 44 cm |
Depth | 25.7 cm |
Height | 4.3 cm |
Weight | 3.14 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
