NetGear S3300 52-port Stackable POE Smart Switch W/10G
£1,161.63
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Auto Voice VLAN for easy development of VoIP
  • Auto Video for simple deployment of IP surveillance
  • Static routing, helps to route internal traffic for more efficient use of network resources
  • IGMP and MLD snooping, providing advanced multicast filtering
  • Extensive PoE+ capabilities extendable to 1,440W with supplemental RPS solution
  • Solid performance with non-blocking architecture, 8K MAC addresses, 256 VLANs, 480 shared ACL entries, 32 static routes, and 1,024 Multicast Groups
  • Comprehensive IPv6 supporting management, QoS and ACL, ensuring investment protection and a smooth migration to IPv6-based network
  • Dedicated SFPs instead of combo ports, offering more connectivity ports and providing better value and usability at no extra cost
  • Energy Efficient Ethernet (IEEE802.3az) support for more energy saving in the future when more EEE-compliant end devices come to market
  • Advanced QoS with IPv4/IPv6 ingress traffic filtering (ACLs) and prioritization
  • Dynamic VLAN assignment for easy user authentication and location-independent access to network
  • USB for easy access firmware updates
  • Type: Gigabit Ethernet
  • Ports: 52
  • Data Transfer Rate: 10Gbps
  • Managed: Yes
  • POE: PoE+
Product codes
The ProSAFE S3300 52PT Gigabit Stackable Smart Switch is a L2+ web based platform : PoE+ in a 48 port configuration. 4 dedicated 10G ports are included as standard (2 x 10GBase-T and 2 x SFP+) for stacking and/or uplinks to aggregation layers or storage and server connections. PoE/PoE+ support between 190W up to 1,440W with RPS (model dependent).
Product Description NETGEAR S3300-52X-PoE+ - switch - 52 ports - smart - rack-mountable
Device Type Switch - 52 ports - smart - stackable
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 48 x 10/100/1000 (PoE+) + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
Power Over Ethernet (PoE) PoE+
PoE Budget 390 W
Performance Bandwidth: 176 Gbps
Capacity VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol Static IPv4 routing
Remote Management Protocol SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
Features Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), DHCP client, Energy Efficient Ethernet, dual firmware images, Strict Priority Queuing (SPQ), Class of Service (CoS), IP source guard
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
Power AC 100/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 34.5 cm x 4.3 cm
Weight 5.54 kg
Localisation Latin America, North America, Europe
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear S3300 52-port...
£1,161.63
