NETGEAR Switch - Managed - 8 x 1000Base-T
£54.43
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Integrated cable management
  • USB charging ports
  • Silent and invisible
  • Easy to use web interface
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: Yes
  • Stock Status: In Stock
Product codes
Traditional switches are not designed to be installed in a living room, bedroom, or office desk, so usually we hide them because the design is not user-friendly - they have flashing LED lights and a bunch of cables that we don't want to see. NETGEAR tackles this problem head-on with the industry's first consumer-friendly switch with integrated cable management. The 900 Series switches are the first switch that you want to display! Thanks to the stylish design and the built-in cable organizer, you will keep your office and home neat and tidy. Moreover the LED ON/OFF button will keep your environment quiet so no light will disturb your movie, work or sleep
Product Description NETGEAR GS908E - switch - 8 ports - Managed
Device Type Switch - 8 ports - Managed
Subtype Gigabit Ethernet
Ports 8 x 1000Base-T
Performance Bandwidth: 16 Gbps , Packet forwarding rate: 11.9 Mfps , Latency (10 Mbps): <76.9µs , Latency (100 Mbps): <9.1µs , Latency (1000 Mbps): <2.7µs
Capacity Multicast groups: 128 , Priority queues: critical/high/medium/low , VLANs supported: 64 , Maximum member ports per LAG: 4
MAC Address Table Size 4K entries
Jumbo Frame Support 9000 bytes
Routing Protocol IGMPv2, IGMP, IGMPv3
Features IGMP snooping, Quality of Service (QoS), Jumbo Frames support, fanless, on/off switches, DHCP client, Class of Service (CoS), power-saving mode, cable management, ingress rate limiting, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), VLAN Tagging, port-based VLAN, egress rate limiting, port-based QoS, port trunking, block unknown multicast, static multicast router port
Compliant Standards IEEE 802.1p, IEEE 802.3az
Power AC 120/230 V (50 - 60 Hz)
Dimensions (WxDxH) 23.4 cm x 16.4 cm x 3.3 cm
Weight 370 g
Localisation New Zealand, United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR Switch - Manag...
£54.43
