NETGEAR Switch - unmanaged - 8 x 1000Base-T
£29.17
Delivery:
Standard: 1-3 working days
Key features
  • Integrated cable management
  • Silent and invisible
Product codes
Traditional switches are not designed to be installed in a living room, bedroom, or office desk, so usually we hide them because the design is not user-friendly - they have flashing LED lights and a bunch of cables that we don't want to see. NETGEAR tackles this problem head-on with the industry's first consumer-friendly switch with integrated cable management. The 900 Series switches are the first switch that you want to display! Thanks to the stylish design and the built-in cable organizer, you will keep your office and home neat and tidy. Moreover the LED ON/OFF button will keep your environment quiet so no light will disturb your movie, work or sleep
NETGEAR GS908 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 1000Base-T
Performance
Bandwidth: 16 Gbps , Packet forwarding rate: 11.9 Mfps , Latency (10 Mbps): <76.9µs , Latency (100 Mbps): <9.1µs , Latency (1000 Mbps): <2.7µs
Multicast groups: 128 , Priority queues: 4
MAC Address Table Size
4K entries
Jumbo Frame Support
9000 bytes
Jumbo Frames support, fanless, on/off switches, power-saving mode, cable management, Energy-Efficient Ethernet (EEE)
IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
23.4 cm x 16.4 cm x 3.3 cm
370 g
United Kingdom
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR Switch - unman...
£29.17
