Nighthawk X6 Tri-band Wi-Fi Mesh Extender creates powerful whole home Wi-Fi using your existing Wi-Fi. EX7700 is one of the most advanced tri-band Wi-Fi mesh extenders that includes a dedicated 866 Mbps 5 GHz band for extending Internet speeds to your devices. FastLane3 Technology with dedicated Wi-Fi Link avoids cutting the extended Wi-Fi bandwidth in half. Smart Roaming intelligently connects your mobile devices to the optimal Wi-Fi for superior streaming as you move around your house. Use the same Wi-Fi name and password for seamless connectivity as you roam around the house.
Product Description | NETGEAR Nighthawk X6 EX7700 - Wi-Fi range extender | Device Type | Wi-Fi range extender | Form Factor | External | Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Dimensions (WxDxH) | 19.9 cm x 15.4 cm x 5.44 cm | Weight | 530 g | Manufacturer Warranty | 1-year warranty |
General | |
Width | 19.9 cm |
Depth | 15.4 cm |
Height | 5.44 cm |
Weight | 530 g |
Networking | |
Ports Qty | 2 |
Connectivity Technology | Wireless |
Data Transfer Rate | 2.2 Gbps |
Line Coding Format | 256 QAM |
Wi-Fi Rating | AC2200 |
Features | Auto-sensing per device, Wi-Fi Protected Setup (WPS), reset button, on/off switches, Tri-Band, Smart Connect, FastLane3 technology |
Encryption Algorithm | WPA, WPA2-PSK, WEP |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac |
Expansion / Connectivity | |
Interfaces | 2 x 1000Base-T - RJ-45 |
Power | |
Power Device | External power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - 90 days |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
