NETGEAR WAC104-100UKS Dual Band 802.11ac Wireless Access Point
£65.17
44 in stock
Delivery:
Standard: 1-3 working days
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 1.2Gbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Compatibility: PC
Product codes
The NETGEAR WAC104 Wireless Access Point is a cost-effective, high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2Gbps. To fully maximize the wireless throughput, the WAC104 is equipped with four Ethernet ports. WAC104 AP operates in standalone mode with an intuitive user interface and a set of two external antennas. It is perfectly positioned for customers demanding high throughput, ultra -superior performance, and extensive coverage deployment for Small and Home Office environments.
Product Description NETGEAR WAC104 - radio access point
Device Type Radio access point
Form Factor External
Localisation United Kingdom
Ports Qty 4
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Capacity Maximum number of clients: 128
Dimensions (WxDxH) 23.965 cm x 18.145 cm x 4.06 cm
Weight 385 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR WAC104-100UKS...
£65.17
