NETGEAR WAC720 ProSAFE Business 2 x 2 Dual Band Wireless-AC A...
NETGEAR WAC720 ProSAFE Business 2 x 2 Dual Band Wireless-AC Access P
£468.91
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Business class with superior 802.11ac performance (up to 1.2 Gbps)
  • 2 x 2 (transmit x receive) with 2 streams of data for 2.4GHz (300 Mbps) and 5GHz (867 Mbps) of reliable data delivery
  • Dual band concurrent operation with backward compatibility to 802.11n
  • Power-over-Ethernet (802.3af) for ease of deployment
  • Ease of use with simple and intuitive graphical user interface
  • Ensemble management for centralized management of up to 10 APs in a single group
  • Comprehensive security with WPA and WPA2 and MAC address Access List
  • Compact and elegant design stylishly blends into the environment
  • Lifetime warranty and 24x7 Support where available
  • Powered by PoE or DC power inputs (PoE switch and AC/DC power adapter are not included)
  • Type: Radio access point
  • Connectivity: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
The NETGEAR 3 AP pack of WAC720 ProSAFE Wireless Access Point is a high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2 Gbps (300 Mbps for 2.4GHz and 867 Mbps 802.11ac for 5GHz) with standalone and Ensemble management for centralized group management of up to 10 APs. WAC720 Business AP operates in either standalone mode with an intuitive user interface or in Ensemble mode for centralized group management of up to 10 APs. It is perfectly positioned for customers demanding high throughput, ultra-superior performance, and extensive coverage deployment for Small and Medium Enterprises, K-12, and Hospitalities.
Product Description NETGEAR Business 2 x 2 Dual Band Wireless-AC Access Point WAC720 - radio access point
Device Type Radio access point
Packaged Quantity 3 (specifications are for single item)
Form Factor External
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Performance Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps
Included Accessories Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 19.7 cm x 19.7 cm x 4 cm
Weight 726 g
Manufacturer Warranty NETGEAR lifetime warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR WAC720 ProSAFE...
£468.91
