NETGEAR WAC740 2 Port Premium Access Point
£386.53
Delivery:
Key features
  • MU-MIMO maximizes the use of wireless medium for delivery of high throughput content
  • Compact and elegant design stylishly blends into the environment
  • Concurrent operation in 2.4GHz (600Mbps) and 5GHz (1.7Gbps) for maximum wireless throughput
  • Backward compatibility with 802.11a, 802.11b, 802.11g, and 802.11n network Devices
  • Integrated Power over Ethernet (802.3af and 802.3at) lowers deployment costs
  • Controller managed by WC7500, WC7600 and WC9500 allowing centralized management up to 600 Access Points in a cluster of controllers
  • Business-class security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
  • Easy mounting mechanism for quick wall or ceiling installation
  • Internal antennas factory-optimized for maximum RF performance
  • Antenna take-offs enable optional accessory antenna attachment for 2.4GHz and/or 5GHz operations
  • AirQual monitors Wi-Fi channel utilization on the network, identify sources of interference
  • Type: Radio access point
  • Standards: IEEE 802.11ac Wave 2
  • Speed: 1700Mbps
  • Rackmount or External: External
Product codes
NETGEAR Premium Business 802.11ac 4 x 4 Wave 2 Wireless Access Point, purposely designed for enterprises requiring high density and superior performance
The NETGEAR Premium Business 802.11ac 4 x 4 Wave 2 Wireless Access Point (AP) delivers high performance with maximum client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC740 is a controller managed Access Point with ease of centralized management with all NETGEAR wireless controllers from small (WC7500) to mid-size (WC7600) and large-size (WC9500) deployment. The WAC740 operates with Multi-User MIMO and can achieve speeds up to 600 Mbps for 2.4 GHz and 1.7 Gbps at 5 GHz. The WAC740 comes with 2 Power over Ethernet (PoE) ports, including one port that can handle up to 2.5 Gbps of throughput, enabling a single wire to connect to 2.5 Gbps capable switch for ease of wiring installation.
  • ProSAFE 802.11ac AP Wave 2 provides a theoretical connection rate of up to 2.6Gbps per radio—roughly double the rates offered by today’s high-end 802.11ac access points
  • Reliable wireless coverage with 4 streams of data based on 4x4 (Transmit and Receive) optimized internal antennas
  • Multi-user MIMO (MU-MIMO) increases efficiency and capacity – enabling clients to utilize the RF spectrum much more efficiently by allowing multiple-AP-to client transmissions, beamforming, wider bandwidth, and improved encoding
  • AirQual feature enables spectrum analysis and interference identification
  • Centrally managed by ProSAFE Wireless Controllers
  • 2.5GBASE-T Multi-Gigabit support eliminates bottlenecks associated with standard Gigabit Ethernet (NBASE-T switch required to obtain speeds higher than 1Gbps w/ a single port)
Product Description NETGEAR ProSafe WAC740 4 x 4 - radio access point
Device Type Radio access point
Form Factor External
Localisation Worldwide (excluding United States and Canada)
Data Link Protocol IEEE 802.11ac Wave 2
Frequency Band 2.4 GHz, 5 GHz
Performance Aggregate throughput: 1 Gbps
Included Accessories Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 19.7 cm x 19.7 cm x 4 cm
Weight 726 g
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR WAC740 2 Port...
£386.53
