NETGEAR's Cable/DSL 54 Mbps Wireless Router lets you experience the blazing-fast network wireless speeds of 54 Mbps - up to five times faster than the popular 802.11b wireless network. These higher speeds make it a snap to surf the Web, download large files, videoconference, stream high-quality digital movies, MP3 music, and photos, and play online games. This wireless router also works with 802.11b wireless products so you can use it with your existing 802.11b devices and your new 54 Mbps (802.11g) devices. Auto-sensing chooses the fastest connections possible on your 10/100 Mbps wide area network and four local area network ports. True Firewall (SPI) advanced security provides maximum protection from professional hackers. URL blocking and e-mail alerts provide parents with controls to limit access to inappropriate Web sites and monitor children's access. It's simple to install, you just follow the cues shown on your PC screen and your router will be up and running in no time. Smart Wizard auto-detects and configures for the best ISP connection, while UPnP (Universal Plug and Play) makes it easy to use your computers, gaming consoles, and other client devices - wireless and Ethernet - for gaming, instant messaging, and other applications.
Product Description | NETGEAR WGR614 - wireless router - 802.11b/g - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g | Frequency Band | 2.4 GHz | Data Transfer Rate | 54 Mbps | Network / Transport Protocol | TCP/IP, PPTP, L2TP, IPSec, PPPoE | Routing Protocol | Static IP routing | Remote Management Protocol | HTTP | Features | Firewall protection, auto-sensing per device, dynamic IP address assignment, DHCP support, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, manageable, E-mail alert, VPN passthrough, URL filtering | Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, UPnP | Dimensions (WxDxH) | 17.5 cm x 11.9 cm x 2.8 cm | Weight | 300 g | System Requirements | UNIX, Microsoft Windows 95/98, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP | Localisation | English / United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK |
Authentication Method | Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, UPnP, FCC Class B certified, UL, FCC Part 15 |
Status Indicators | Port transmission speed, power, link/activity |
Line Properties | |
Line Coding Format | DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 |
Aerial | |
Directivity | Omni-directional |
Gain Level | 2 dBi |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | UNIX, Microsoft Windows 95/98, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP |
Dimensions & Weight | |
Width | 17.5 cm |
Depth | 11.9 cm |
Height | 2.8 cm |
Weight | 300 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 10 - 90% |
The following resources are available for the NETGEAR WGR614 Cable/DSL 54 Mbps Wireless Router - For Cable Users
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
