The NETGEAR Wi-Fi 6 AX1800 PoE Wireless Access Point (AP) delivers 802.11ax high performance wireless connectivity for Small Office and Home Office (SOHO) deployments and supports dual band concurrent Wi-Fi 6 operations at 2.4GHz and 5GHz with a combined throughput of 1.8Gbps (600Mbps at 2.4GHz and 1200Mbps at 5GHz). The WAX214 Wi-Fi 6 Access Point provides standalone configuration with easy setup for a reliable, Wi-Fi 6 802.11ax high performance, and cost-effective wireless solution. The WAX214 can be powered by Power-Over-Ethernet or a DC power adapter.
Product Description | NETGEAR WAX214 - radio access point - Wi-Fi 6 | Device Type | Radio access point | Form Factor | Wall / ceiling mountable | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac, 802.11ax | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum throughput (2.4 GHz): 573.5 Mbps , Maximum throughput (5 GHz): 1201 Mbps | Capacity | SSIDs total: 4 | Dimensions (WxDxH) | 16.09 cm x 16.09 cm x 3.328 cm | Weight | 380 g | Manufacturer Warranty | 3-year warranty |
General | |
Width | 16.09 cm |
Depth | 16.09 cm |
Height | 3.328 cm |
Weight | 380 g |
Networking | |
Connectivity Technology | Wireless |
Wi-Fi Rating | AX1800 |
Status Indicators | Power, LAN, 2.4/5 GHz |
Features | Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), reset button, SOHO (Small Office/Home Office) |
Encryption Algorithm | WPA, WPA2, WPA3 |
Authentication Method | Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6 |
Aerial | |
Antenna | Internal |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-TX (PoE+) - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | EN 60950, CB, EN 62368 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Technical support - 90 days |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 95% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
