The NETGEAR N300 Wireless USB Mini Adapter allows you to upgrade older laptop's Wi-Fi and connect to Wi-Fi hotspots. Mini-design makes it perfect for mobility. Push 'N' Connect gives you a secured connection at the push of a button.
NETGEAR WNA3100M - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
3.4 cm x 1.6 cm x 0.8 cm
4 g
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, USB 1.1, USB 2.0, IEEE 802.11n
Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Push ‘N’ Connect button
1 x USB 2.0 - 4 pin USB Type A
Software Included
NETGEAR Genie
3.4 cm
1.6 cm
0.8 cm
4 g
Customer reviews
