NETGEAR WNA3100M-100PES N300 Wireless Mini USB Adapter
£18.91
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Mini-design
  • Perfect for mobility
  • Push 'N' Connect - push button security
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Form Factor: External
  • Compatibility: PC
  • Type: Network adapter
Product codes
The NETGEAR N300 Wireless USB Mini Adapter allows you to upgrade older laptop's Wi-Fi and connect to Wi-Fi hotspots. Mini-design makes it perfect for mobility. Push 'N' Connect gives you a secured connection at the push of a button.
Product Description NETGEAR WNA3100M - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 3.4 cm x 1.6 cm x 0.8 cm
Weight 4 g
Data Link Protocol 802.11b/g/n
Data Transfer Rate 300 Mbps
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, USB 1.1, USB 2.0, IEEE 802.11n
System Requirements Microsoft Windows Vista / XP / 7
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR WNA3100M-100PE...
£18.91
