We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The WND930 Outdoor Access Point is a dual band concurrent 802.11n Outdoor Access Point that combines high power, optimal high gain antennas, and an industrial grade enclosure for optimal outdoor deployment. The WND930 Outdoor Access Point is powered by redundant dual Power over Ethernet (PoE) gigabit ports as well as the capability to power other PoE devices. The WND930 Outdoor Access Point operates under harsh environment with its industrial grade IP-67 enclosure and an embedded heater to allow the Access Point to operate in below freezing point temperature.
The WND930 Outdoor Access Point is ideal for hotels, resorts, schools, multi-dwelling apartments, and other locations needing high throughput, high capacity outdoor coverages. The WND930 Outdoor Access Point can operate either as a point-to -point mesh link between remote locations or as an Access Point providing coverages for users. As with all NETGEAR wireless products, the WND930 Outdoor Access Point is designed with an easy setup for a reliable, high performance and affordable total cost of ownership.
Product Description | NETGEAR WND930 - radio access point - Wi-Fi | Device Type | Radio access point | Form Factor | External - outdoor | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0) | Frequency Band | 2.4 GHz, 5 GHz | Included Accessories | Pole mount, mounting brackets | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 22.5 cm x 25.5 cm x 7.8 cm | Weight | 1.894 kg | Manufacturer Warranty | 2-year warranty |
General | |
Ruggedized Design | Outdoor |
Width | 22.5 cm |
Depth | 25.5 cm |
Height | 7.8 cm |
Weight | 1.894 kg |
Networking | |
Form Factor | External |
Connectivity Technology | Wireless, wired |
Status Indicators | Power, active |
Features | Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS) |
Encryption Algorithm | WPA-PSK, WPA2-PSK, WEP |
Authentication Method | Basic Service Set Identifier (BSSID) |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at |
Expansion / Connectivity | |
Interfaces | 2 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 4 x aerial - N connector |
Miscellaneous | |
Compliant Standards | IP67 |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 10 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
